photo1x1.com
- Joined
- Sep 14, 2016
- Messages
- 923
- Reaction score
- 289
- Location
- Austria/Europe
- Can others edit my Photos
- Photos NOT OK to edit
Thanks, Joe - much appreciated! I redid the test right away. Luckily my orchid wasn´t dead yet.Wow, I thought this thread was dead. Love the conversation (believe it or not, I read it twice), despite it seems "a little" off topic by now.
Not being native English, I again feel the wording could be better. ISO invariance implies to me, that it would make no difference whether I push an image 1EV in Lightroom, or 5EV, which would be "100% ISO invariance". Am I wrong in this regard?
Right. ISO invariance basically means the read noise in the system no longer matters. You get the same result from digitally scaling the data in post as you would get from applying analog gain to the sensor signal prior to ADC.
When would you consider a sensor being ISO invariant? How much would you have to be able to drag the exposure slider without adding anything unwanted (noise - or what you would call it, color shift,...) to call a sensor ISO invariant?
That's why I like Bill Claff's website and test data as opposed to other sites like DXO. Do we set that standard based on what a machine can measure or on what we can practically see? Bill for example rates your camera's DR capacity at 11.6 stops. DXO rates it at 14.7 -- I believe Bill. In referring earlier to my XT-2 I said it was for all practical purposes ISO invariant. I'm sure there's a machine out there that says it's not ISO invariant. In the end all that matters to me is can I take the photo.
I have done some ISO tests a few months ago, that I repeated last week with a different background to better show the difference.
I also did an ISO invariance test with ISO400 on my Sony A7III. Reading the conversation, I should have done it at ISO100, or ISO 640 (according to this graph Photographic Dynamic Range versus ISO Setting), is that correct?
Correct. Your camera is most certainly not ISO invariant and very ISO invariant both at the same time -- just like my Fuji. Your Sony is fitted with a dual impedance sensor. The sensor has two read channels. You've got ISO invariance in each read channel separately but not across them. Your test here compares the two channels one to the other -- NOT ISO invariant.
Oh yes, and one more question, if somebody would be willing to answer: why is the input-referred read noise in this graph: photonstophotos.net/Charts/RN_e.htm#Sony ILCE-7M3_14 higher for lower ISOs?
Dual impedance sensor -- it's really like having two sensors in the camera, one for low ISOs and another one for high ISOs.
For those of you interested, I have uploaded the RAW files here: http://www.amriphoto.com/forum/ISOInvarianceTest.zip
In regard to noise, I feel the ISO400 files keep up pretty well up to pushing them +2EV in Lightroom and comparing them to ISO3200. But to be honest, I do see quite a difference starting at +3EV when pixel peeping.
So my conclusion is no real surprise: you have to decide when shooting: is it more important for me to have a higher dynamic range or less noise. In the particular case of my orchid, I would have gone with less noise.
I know this is not a scientific test as it was done with (quality though) LED lights, but it should give a good impression.
Here is a sample - which one do you think is ISO400 +3EV in Lightroom, and which is ISO3200?
Sorry to do this to you but you need to re-do the test and stay in one or the other of the two impedance channels on the sensor.
Two more concerns with your test data: 1. If you look at all the EV 0 exposures in RawDigger you're nearly a full stop underexposed (defined in this case as reaching sensor saturation). 2. Sony is notorious for cooking their raw files and slipping in some lossy compression. I don't know specifically about your camera but that may be a factor.
There's another complication to this topic that needs to be considered and that's the external processing software. All raw converters don't take the same approach to what they're doing and it can matter a lot in this regard. How to assign value to this difference is personal so I think both choices are entirely valid. If you've ever spent time programming a computer you know that there can be a huge difference in performance based on math precision. If you really want to keep computer software moving fast make sure all the math stays integer based. Nothing slows down a computer processor like math with floating point numbers.
The above said processing speed is a critical issue for raw conversion software and I believe LR has its thumb on the scale tipping toward speed over precision. You may be quite surprised to compare the same test processed in LR and then again in say C1 or SilkyPix.
Joe
I exposed it one stop brighter, and used ISO100 and ISO640 for the test. I also checked the images in capture one. Still, starting at +3EV noise starts being pretty visible compared to the higher ISO shot. I didn´t use capture one in a while and was impressed by their noise removal algorithm.
For those interested, here are the RAW-files: www.amriphoto.com/forum/ISOInvarianceTest2.zip
May I refine my question:
I did know about the dual impendance, having read quite a bit about ISO invariance recently. However, I wonder why the input-referred read noise is higher in lower ISO-regions, I would have expected it the other way around. That confuses me. What exactly is that input-referred read noise?Oh yes, and one more question, if somebody would be willing to answer: why is the input-referred read noise in this graph: photonstophotos.net/Charts/RN_e.htm#Sony ILCE-7M3_14 higher for lower ISOs?
