rgregory1965
- Joined
- Aug 15, 2011
- Messages
- 711
- Reaction score
- 84
- Location
- arizona
- Can others edit my Photos
- Photos OK to edit
??? The LED's aren't going to be enough to light a portrait. You'd need about 100 of them. Continuous lighting is cheaper, but you need a LOT more of it to equal one strobe. Strobes are so much brighter!!! To figure out how much brighter it takes a little math. If you use a 500-watt continuous light at a 1/60 shutter speed, divide 500 by 60. Your 500-watt light gives only 8.33 watt-seconds.
So, the 300WS strobes would need to have a total of 36-500watt lights to equal ONE 300WPS strobe at 1/60 per second.
I have a SB700 and a set of remote triggers.....so I guess maybe one good lite for now would work along side the strobe.....lights are easier on the eye setting up....you dont have to keep flashig to get the light you want.
Just be aware of what you are purchasing with those-they're disposable. The flash tubes are not user changeable and when they are done-they're done. They are very low budget/quality lights. They are great in a pinch if you have no other option, but the durability, control, color and output consistency are not exactly good. The softboxes are incredibly small to work with too and won't boot up to another good strobe when you do dispose of the flashes.I have my eye on a similar set, but not this particular one. Still trying to figure out if I want a new tripod, Tascam DR-100, or the lights. I do independent film as well, so sometimes they work together and sometimes as in the case of the DR-100 they don't.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
You and many many people who have bought them...Thanks. I'll look into something else then. I had no idea and would be pissed lol.
Not a problem. Just set a custom white balance in the camera for the color of the light. You don't need white light. You just need light that has a single color temperature. If the color temperature changes with the power setting, just set a new custom white balance.....but see alot of people say that there set produce yellow light......can anyone suggest a starter set that throws nice white light.
