Mikhal
- Joined
- Sep 24, 2018
- Messages
- 150
- Reaction score
- 110
- Location
- Wisconsin
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
The light does want to be on the face, but not flat, even light. try for more of a "modeling" light which will articulate the facial contours. Have your main light coming in at a slight angle to the face.I feel like I had a little more success with the natural light as well as more patience to get a better shot. I do have a flash where I am able to adjust intensity and direction but I haven't had the opportunity to mess with it, maybe that can help some of the lighting issues?
Derrel's suggestion of bouncing the light off a surface is what you want to do. If you don't have a white or nearly white wall or ceiling, get a large panel of white foamcore to act as a reflector. You can even use someone's white shirt in a pinch. Position your reflecting surface at an angle to your subject's face, and bounce your light off that.
Yes, you can use daylight coming in a window for your main light, but it will be pure chance if you get good light at the exact time you want to use it. Which is one reason pros use flash. They need to get the shot when the getting's good.
So by flat light you mean there are no shadows to highlight parts of the face?
The house does have decent light, but it doesn't have it where I have the space to take the photos, def going to start working with the flash to see what improvements that brings.
Thank you for the insight!
