Night shots out of focus
Nam Le
Hi guys,
I'm a newbie trying to picking up night photography :) I'm using a Canon 600D and 18-55mm kit lens. I wanted to take sharp, crisp photos of Singapore scenery at night. So what I did was using a tripod + smaller aperture f/21 and using a remote control, ISO 100, shooting in raw. I use manual focus and set exposure time to 1-2 mins. But the results are quite bad :( I don't know why I can't get the buildings focused and there is noise even I used ISO 100.
Is anyone kind enough to give me some tips on how to make my photos better, as in focused, brighter, more even lit, etc.? Thank you :)
cRIS-vK0X-mDDyXr474Yo1ExguX0hPGJosgXqv9b9HnzRHLNPurShPsT9M7AJ-GGwh47iP5-bwa5KpO9Kz6euPkgFE66XTgqajh4ySgzfT48qPXf6ToJnonRdM5GUq8gfgC7jmunlFWtqx8lmrwczQYQ01pd6pv_49Xlz2B944kd2EyY16eiCc_WHoqtlJhYvFb8HEgqhq-l22GuvpKmR9Xp7dHuU-LpbInSFgZWEho7unoXRyZl_-VhUQiuT4qGPCR78ZJdpMfZOufJcmzPq_zPL4OZog-X54GJQC_fyighFS0w6eN9hmVMNRkUTN3FOiY4MRyMQ8-aPsWLDyTpcwjSY3LVabTSXRiSC_y7lYIaMaAfkIF152mw3zgNT37UWKfsnhJqwApeUQBVNe1uHG4ClchGgiHcyfhd5yzl87-C8COmoU9nFeskT1wKx_150UBH8BZo-NwJthUYiHYmXOoYJ3ro5hJkISn9H2TCbQFE9ecsqBUrpLQeTzjjrwafZkF2YDB6LGdiScKgNaYzqCLdlSNppdrAz6s_HgxfsEk=w1259-h839-no
EcpXbqPfh7lGUHDQMKj8vVJ4jEgRfOrk4xuv9YY5XMZYAUPelU4eZTgQXr9cRbFsWChM98ndbDmoimOjpelhWQ_DPk_B7KAb9jagSsNvi80eVeqkj5xNLlISo740iYKEskirHrxnZoaE1CLYe0wgrlMmHOnpoen13HX5DA60O4d96uvF8mqGy2XMfNzCE8RLzm5UILejGZdJ6HIUuU4mSEF5Seire6r6vNvPp5jzd9r6uOotLRYymWaTzHW0VUu5Ba9czKFJAiG6Ajxj_w2ZIVsZTPXp-q0k5OxCMtLXF0eCjpcmMOj9Vxri-zre8j9l83hla7CmsNYeEW0RzVThavE98A0FMhst5Jq5v4TQkLx7gCiyejPSRmYcHFX_9fDlrn1iutNojS2tGD4a7kLYZAQA-L3ZpySFQDcKyAuyelp-tF9PHeyEmhrqQpwbRxxZrzh5-_zdXcx5L4JJLjc_DwgO9wYgkpD5GcMTLHbEqtxq_QIz4nYZ-ftIQ-EuxXE-Ozm95XK5KxWhytQ8SH-fO8CwYsUrzV3gESDoZINJYOE=w1259-h839-no
ejyQu7BBkiKve9yZWzcjD5mk_lzDHudTueibGQ6sD6q8USYgpyFX4btMRbGeOv9ksTNa5EtbP-3ClmS-Ki0PnUhOFerqJK-57u_rcoO2YZ3glx_PLB9EpGufEDhpYT8Et9jF3vAZmlVdh3uN2FIVAYGMgs0JxPihRROAkJid8nQFLXNIgB4oZvkjqHfvpfhHLvHpyQ-myTf0fSEmxfpQuK2yRVYd8oM5vwOAEM3RJOberKCt5k5VVRsl5kJ32ivWI12F66UrhgK1ns6vNDpSjg6g4Aqzc55om0Jh6jQfrIjVJrka0GPy4p4dZe96FvPio4GbUFqcPZOfputdVQ62FeUTArB0XSJbkoOaiA0jY0D_mVK2UkXSpJaTVazIIUOsog18wKwhRrzGx0dy03qA5tuoVywsPPWKnmMS78PStfjW1AjR0fQqeVK9WvzEvJKsDamx2kUBO9mFebNyHTkSqzed2fjt2lhqRSd95Rz5oQAsWkBKkiiE4OMOqa0ZRxp3UXAWnr1mR08oGlyD5jW424D5ujfG0Ku23vXvK_W0iHE=w1259-h839-no
YdBvBf_x4XRQuCXsysre-as29EtxHPBwVHgx_TuoK0xy8x28yk4VhhwxT35uRYzy-iLTNjBPdpbFxf26gmudhQoNAK87dKqBXRZqyPbeoJm6Zn_75o0jMZyUfsqN1GaLY7oMJsCRpdwpSDfUabiANmLSgQ18dx51Gn0aGBarPZApvcevU4cYFbbMQ7UjdjI59WNmnBuJUL6h5MwagVSPixPFiBJL6BPKg3UCQ8UjB5mhMBusJJ-aYVRQRKeTPkCfP2WThIT7nUwrh26fY19Wrc6JpIqr9xoeQkrRA-wkkhx8iImy9HHawGKtynbeEe8LHZCW_tpDbv677VboExmkflcSO8in56XjaB2yGCigeMFMh9hDO11nPahmk-RC8Ka8y0ZsYnvqG6R83fdnkMPB7hy7XRQ6jdreXvYnyHZ62mpD-3JgkpWICWJO6pkIQzhdX_YTCoVfwSyJWmCc6n8PxcYEz0xpps2N6IoxiwnELH5CocOXHVjBCE2X5PEUnp4_ymVDohiJoW6DlLbGk55wrEYnXERJNO5apYbevGduUts=w1259-h839-no
I don't see a bad focus problem. I see a pretty powerful color cast in a couple, which may or may not be desirable. Digital noise is introduced not only at high ISO but also during long exposures, even at ISO 100.
I would honestly use auto focus, and if using manual focus make sure you find the correct hyper focal length for your lens.
Two questions, What tripod are you using? and was your IS on?
Make sure your tripod is very secure. Add weight and stableize against camera vibration. Also use the timer and second shutter when doing long exposure. Also, a remote or wireless trigger will help.
Not sure if you did any of this, but these things come to mind when you say tripod.
I'm not an expert at this type of photography, or any other type for that matter lol, but try again at f/8 or f/11. And make sure you don't under expose, having to bring exposure up in post will really bring out the noise.
Wow very helpful, thanks guys!
@spiralout462: I can't attach here a full res photo, if you zoom in you can see blurry details. Long exposure can produce noise? Will check that out, thanks.
@EIngerson: I use a Slik carbon fiber tripod, came with the camera sale. I think just a standard one. I tried both with and without IS but not much diff. Some said IS helps some said IS actually worsens the focusing, what's your opinion?
@BillM: ok, will try, thanks :)
If you are on a tripod or shooting action at high shutter speed IS serves no purpose. Not necessary. Not a great tripod, but not too bad either. Like I mentioned before, add the weight to stabilize it. No need to buy expensive gimmicks for weight. Be creative and rig something up that isn't too cumbersome to travel with.
Also, I noticed you were shooting at F21. I usually shoot night scenes between F8-11.
Good luck and have fun.
Thanks EIngerson, will try :)
Your camera has a noise reduction system for long exposures. How well it works and whether it is worth using in most situations is debatable; Night shots with 600D: Canon Rebel (EOS 1200D-300D) Talk Forum: Digital Photography Review
Use the mirror lock up feature to prevent camera movement.
Also, switch off the image stabilization circuits when using a tripod. The servo network of the IS system will create blur when used on a tripod due to the motor's internal vibration. The longer the exposure, the more vibration will be recorded.
Was there any wind or vibrations? 1-2 min exposure is a long time for something to sit completely still, even on a tripod.
To add to the above
If you are taking such a long exposure then when you use a remote shutter to activate the shutter you don't want to be standing next to the camera. I've found even on a concrete platform that walking here and there and not standing still introduces some shakiness. If you are on an even less stable platform then just walking around the camera while it is in an exposure is going to introduce movement.
Then add any heavy winds, etc. which you'll have to position yourself to block direct wind.
I'm not 100% sure on how your camera works but my tips are:
Use the 3 second timer if you don't have a remote. Usually also engages mirror lock up mode too.
Use live view and magnify in on a light to confirm focus and manually adjust as necessary.
I like f16 as a nice balance that also usually creates nice starbursts.
Look up "exposing to the right" technique.
Thanks guys, looks like it all boils down to the vibration. Yeah, Singapore is quite windy, I will try a larger aperture and shorter exposure time and see how I can secure the tripod :)
it really depends on what your subject is...ie how far away it is. Are you shooting a night panoramic? Are you shooting a night portrait? both require very different techniques.
if you are shooting a night pano with out much light then manual focus is your friend. set the focus point at infinity and shoot way.
if you are shooting a night portrait then your on camera focus assist or focus assist beams on your hot shoe flash should do the trick.:1219:
besides the vibration, unless you have poumped up the color in post-processing I think these are overexposed, and the reds are super-saturated.
Lowering the red saturation and the exposure overall plus some noise removal, makes at least this one look better.
Hi Amitbhatt, thanks for the tips, I am trying to capture night panorama. I used manual focus too, the objects (building) are very far away, I think around 1-3km.
