Nikon: CLS vs SU-800 vs Pocketwizard?
I went best of both worlds, my sb-600s as slaves on some pw flexes and a su-800 mounted on a pw mini. I can control every flash from the camera and not worry about the IR finding it. There's a video on pocketwizards website about controlling speedlights this way.
Inside the su-800 is almost always fine by itself, if you get good with it you can even bounce the IR signal around corners. Outside is a little different because there is nothing to bounce the IR off of, that's where radio triggers really help.
That does work pretty well when I am using the Speedlights for anything serious. I usually use the SU-800 on my R1C1 macro setup... but it does work well with the TT5's!
The PW mini, SU-800, and Flex really does look like the class way to go if you can afford it.
