- Joined
- Mar 8, 2011
- Messages
- 25,329
- Reaction score
- 9,109
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
How about a Nikon D600 AND a D7000?
Why?How about a Nikon D600 AND a D7000?
I have those two and I barely use the d7000 anymore.
but with the upcoming soccer season and my son on a larger field ... I may need something longer than the d600 and 80-200.
I'll be running a test when practice starts.
I kinda wish I had the d7100 24mp for more cropping.
Another vote for D700.
First off, I have cameras with better video capabilities than any dSLR (not that it is that hard. Most dSLR video is mediocre and the D600's video is nothing special). If I want video I will use a camera designed for video.
The D700 is much better built, that goes without saying. Adding the grip and the D3 battery gives you 2500+ 12-bit RAW files on a single charge. The AF is not just a little better, it is far superior giving faster focus acquisition and that just gets better and better the darker it gets. 51 focus points vs 39 for the D600. I cannot recall the last time I missed focus shooting in dark conditions with the D700. When playing with the D600, I got a surprising amount of lens hunting as the camera struggled to focus on what I needed, something the D700 never did for me.
High ISO is better. I can shoot with confidence at ISO 6400 all day long. The dirtier higher ISO also cleans up a little better than the D600. That means that there is more detail in higher ISO with 3rd party noise reduction with the D700 than the D600. I have shot weddings with the D700 at ISO 25,600 and with minor cleaning in LR 4 and had great results. I could not equal those results on a D600. It's almost like it has problems with chroma noise... quite a lot more than the D700.
The D700 has an integrated flash. In an emergency, you have a flash, but even better when NOT in an emergency, you have a commander that can control up to a full 3 groups of flashes in manual and/or TTL using Nikon's CLS. With the D600 you have to add an on camera flash with commander capabilities adding several hundred dollars cost to your kit.
The D700 has an integrated focus motor. The D600 I believe does not. This means that if there is no focus motor in the lens, that lens cannot focus automatically. Lenses like Nikon's Nifty-50 that work wonderfully on the D700 are merely a manual focus lens on the D600.
Greater range of shutter speeds. The D600 maxes out at 1/4000 while the D700 maxes out at 1/8000th like most of Nikon's cameras.
12.1MP. Smaller file sizes. Who *really* prints photos at sizes above 16X20 inches on a regular basis? The D700 has given me excellent 30X40 inch prints and downloading 500 files from a 16gb card happens quite fast. I get barely 250 files on a 16gb card with the D600. That means I would need to pay for a bigger card to hold the same number of pics. I also need bigger hard drives to hold an equal amount of files. Not a biggie, but it is another extra cost.
If all one does is post to the web, heck a good 2mp camera is all that one needs, anything above that is overkill. That 12.1mp size is perfect for any use with no real disadvantage.
They say that the D600 has 2 stops more dynamic range. That's nice... show me a picture where that advantage is VISIBLE. For 99% of photographers, this difference is not easily visible on anything under a 16X20, and even at that size, you'd better have some real good eyes to spot the differences while pixel peeping.
A couple people complain about the layout of the camera... the D700 has the same layout as the higher end Nikon cameras, the D600 has the same layout as the other lower end Nikon cameras. I make changes more intuitively on the D700, but then again, I also have and own a D4, and can switch back and forth without thought. This is not a good or bad point, it is simply desire to learn a new layout and preferences.
Build issues. The D600 has been having oil on the sensor issues for months. Even after cleaning several times it often comes back. This points to a build issue, not a cleanliness issue. The D700 came out with no major issues and has been rock solid from day 1.
Where the D600 comes off as a nice consumer camera, the D700 is a true PROsumer camera, and I feel the D700 is always going to be the better camera. If all you want is video and bigger files with no real advantage over the D700, the D600 is the tool to get.
That's my 2 cents.
Ummm, the D600 has a built-in flash that can be used as a commander for Nikon's CLS/AWS. It also has an AF motor so it does not require AF-S lenses. Those are just two of the areas where you're completely off.
Yeah. I didn't really feel like pointing out everything.....Ummm, the D600 has a built-in flash that can be used as a commander for Nikon's CLS/AWS. It also has an AF motor so it does not require AF-S lenses. Those are just two of the areas where you're completely off.
just two of the many.
