Noise Reduction in Post
tyqre
MA
What is the best software to do noise reduction in post?
There are several programs that do a good job. Check out Topaz labs, Nik , Noisenenja.
If you have to correct for noise it should be done first.
ill check out Lightroom first considering that i already have it :)) ha fail.
I use them all depending on what my nr/sharpening goals are.
Noiseware Pro offers options and adjustments ACR 6 (Camera Raw/Lightroom) doesn't have.
I use Lightroom3. You need to to learn how to balance noise reduction and sharpness.
this is one thing i seem to fight in allot of my pics. downside of an entrylevel camera i suppose. i have CS5 and im just getting into it. workig on learning the whole processing tequnique while learning the program. are other programs that much better at reducing noise compared to the feature build into cs5 that would warrant a purchase. and this is someone who just does this for a hobby.
Neat Image is another 3rd party option you can consider using; its demo version acts as a standalone program (ie you load the photo into it outside of photoshop) and only saves in JPEG, but that is certainly good enough to test its noise control abilities. It also has a sharpening code as well which I find a good option to combine with the noise reduction
Neat Image - best noise reduction for digital cameras and scanners
(strictly speaking you should do them separately - noise reduction then sharpening; though for most webbased applications and on most photos you can get away with a good result by doing both in the same stage).
This is however one area where there are no real clear market leaders, specific situations and noise profiles can result in one program having the edge over the others, but generally shooting within those restrictions is impractical/impossible in the real world. The major differences are going to be the controls and how well you can fine tune the results with each option; and that requires learning to use the tool well to see the small differences.
I think topaz denoise works great. The presets are all you need. Unless your originals are extremely noisy the plugin won't take much detail away, if any noticeable at all. You might lose much detail if you're reducing noise in a pic of an extremely fine detailed pattern.
