off camera flash question, white wall became black background in photo
minn
Hi, All
I thought this subject probably is at intermediate level of photographing, and I am newbie though. Simply curious how the white wall could become a dark background using one bare flash off camera. please see the image attached for understanding my question
I have been searching for answer quite while, and still could not get there. can anyone please help me? thank you
Kindest Regards
Minn
the light falling on the wall is exponentially less than on the subject. What's that formula? Anyhow, if she was closer to the wall it's be lit somewhat more. If you truly want the white background you'll need to put lights on it.
Thanks, Trever. what I wanted is the dark background, the trick here is to convert the white wall into black.
I knew the shutter speed controls the ambient light, so, I can purposely lower the exposure to make it looks dark.
in the meantime, the aperture controls the flash light. I can cast the highlight on to the model
now, the problem is once the flash sparkles, the light goes everywhere to turn the background back to white again. how to fix that, and keep the background still dark but the model in good spot light?
Add more light. Turn it up higher, use higher aperture to balance exposure. Try something like f8 or f11.
Unless you have a HSS capable flash (probably unlikely) there is only so far you can got with shutter speed.
Decrease your shutter speed. in some mode take the shot for proper exposure (without flash) this will show the background. make note of the cameras choices ISO shutter ap. Then set camera to Manual and enter those settings turn on the flash and take your shot. Usually a tripod is mandatory in such a shot to prevent blurring the background unless that is the effect you want. The main subject will not be blurred as it is illuminated by the very fast flash. ETTL mode on the flash is easiest for this, but you can manually set the power with a little experimenting. This is a common technique used to when taking a subject in the foreground against say a late sunset or interior.
As Trever1t mentioned it's to do with light fall off. As the distance from the light source increases it has to cover larger areas. (Numerically its an inverse square relation ship.)
To light your subject but not the background the light would be much closer to the subject than the background. Ideally this involves having the background reasonably far from the subject as having the light source close to the subject tends to produce hard shadows, which can be dramatic but is not flattering.
With off axis lighting flags can be used to control the parts of the image that are lit so with side lighting it's possible to arrange the lighting to fall on the subject but not on the visible background.
Thank you all for the good advices, here is what I did
- aperture set to f13 which is the maximum I could do, otherwise, the camera doesn't shoot. don't know why though
- shutter speed set to 200 which is the maximum when using the speedlight E-TTL mode
- ISO 100
I feel closing by the flash to the subject made it happen if I am not wrong, thank you Petrochemist, and it is true the light is not flattering.
just don't quite sure what do you mean by "With off axis lighting flags can be used to control the parts of the image ... ... ". probably I need to digest a while before understanding this trick.
Hi, Didereaux, thank you too for shedding me the light, the issue with me is I am still blind to what you suggested, I am sorry for this. I thought decreasing shutter speed will increase the amount of the light hitting the sensor, how is it possible doing this would preserve the dark background which I adjusted my parameters to catch ?
- ISO 100
the ETTL on the camera/ reads the light on your focus point. What happens with slow shutter is this. You will see the subject and bckground but if you do it right the background is slightly underexposed, as well as the subject. While the shutter is open light from all sources is coming in, since the flash is NOT reaching the background when the flash goes off (it is very very fast thousandths of a sec you in effect have a double exposure....the background then the flash lit subject. Play with it, it is easier to do and understand than to read about it. As I said this is a very common technique used by pros and advanced amateurs alike.
The simple advice you will read usually is something along the lines of this: Expose for the background light the subject with the flash.
Setup camera, without flash, so you get the background you want.
add flash to the subject to fill in where needed.
Thank you, Sir, I will try to experiment this and see the good results
- ISO 100
Perhaps I can explain better. If the flash is near the camera it will be sending light in much the same direction as the camera is looking. Move the flash to the side or up (~45° is common) then a a flag (dark sheet/card etc) can be used to block the light that would fall on the background behind the subject. This can still be done with large diffuse light sources. Together with a reflector to fill in the shadows it can produce a nice soft light while still not lighting your background. Getting it right probably takes quite a bit of practice :)
Good explanation, Sir.
The reflector thing, do you mean the reflector serves reflection and blocking purpose ? I guess it will be placed opposite to the key light, if this is the case, probably there is a need to prevent the key light from spillover particularly when using large diffuser at 45 and not far enough away from background such as in a living room, correct me if I am wrong
I take it you want the black background and you have a white wall.
When you noted that you stopped down to f/13 and the camera would not let you go further; I think that by stopping down the aperture the flash went to higher power and at f/13 you maxed out the flash unit capability and from there it would not let you stop down any further. I would have tried a larger aperture and lower the flash power.
By far the easiest way to try it out is be in manual mode for the camera exposure and can have flash in either TTL or manual (TTL and some flash compensation or manual and directly set the fraction you need, like 1/16 of full power).
Get your model as far from the wall as possible and that can help a great deal with making the inverse square law work to your favor.
Hey, Dave442, thanks a lot help understand the f stops concept, now I have one more element in my equation, that's the flash power on top of shutter/Aperture/ISO. it's really fun pulling these concept into practice
It's the inverse square law! Basically as something moves away from the flash it needs greater and greater power. If you put the subject very close to the flash so that you only need a very low power and move the flash an subject away from the wall, then the light "falls off" and doesn't expose the wall. Also, snoots and scrims can help to accomplish this.
