One side of the photo out of focus
mozartain
Virginia, USA
Hi guys
It's my first post here. Happy to be a part of this community.
Consistently, the left side of my images is coming out blurry/out-of-focus as opposed to the sharper/in-focus right side. A couple of samples here:
I use Canon Powershot S2 IS. It's a four-year old camera, so my guess is it's the tired lens itself where the problem lies. But it can also be a case of some accidental change of setting which I'm not aware of. If it's the lens, is there any remedy? And if it's a setting issue, any idea what that could be?
Thanks for your time. Cheers.
Mozartain
Just a guess...but is it possible the lens has a bit of oil or grease on it? May need a thorough cleaning? I'm certain more people will have better ideas...good luck!
It looks like you need a lens cleaning maybe.
It looks like an glass element in the lens has moved. I doubt a lens cleaning will address your problem.
It is also possible the image sensor itself has moved out of place.
It looks like either your lens or camera mount need repair--most likely the lens. The lens elements are not inline with the sensor.
Are you sure that the lens was mounted correctly? It's unlikely that the camera would work if the lens mounted crooked, but you never know.
Their camera, the Canon Powershot S2 IS, doesn't allow lens interchangeability.
