Opinions needed - which to print?
cannpope
North Carolina
I would like opinions on which of these images I should print to hang on the wall in my office @ work. The wall is a medium grey and the trim is white. I just can't decide. And what would be the largest size to print that will look ok?
Im a huge fan of the B&W, however all three are great images.
Happy Shooting :-)
I'm a big fan of color pics, especially if you are going to hang it on a gray wall. Nearly any color should work, IMO.
Depends on your printer or where you plan to have it printed. Check the specs on the printer, and you will see something called "resoution", as expressed in dots per inch, or DPI. Size your print to fit within the printer's optimum size (inches) multiply by the DPI, and that will give you the maximum size (in pixels) you can print while keeping the sharpest image. Of course, you can still ask to have it printed larger, but you will see little "steps" in the curved areas.
So how big is the picture now? Got lots of pixels? Good, then you can make a fairly large print.
