Photo Neutral Density filter help?!
Hello,
trying to select a neutral density filter for my Nikkor Fisheye 10.5 mm ED lens.
How do I determine if i need a 52mm,58mm,62mm,67mm,72mm etc?
confused, please help.
Thank you interwebs!
Brian
The lens has a built-in, rear-mount gelatin filter holder slot, which would be a great place for ND filters. Nikon used to have a template on-line, so you could print it out and then lay it over sheet ND filter sheets, and cut out all the ND filters you wanted.
Not sure about the front though...wish I could be of more help.
