A traditional "close-up lens" (really a single-element diopter) basically works a bit like a magnifying glass. But the problem with this is that the middle gets magnified without much distortion, but if you check the edges you'll notice they aren't quite as good. Depending on your subject, however, you might not actually care about the corners & edges ... so it's no big deal.
Canon makes an achromatic "doublet" close-up diopter which does a much better job in the corners (but it's more expensive than most close-up diopters... still not nearly as expensive as a lens). There used to be another company that made them -- but no longer does (it's been long enough that I no longer remember the brand.)
So today your choices are:
1) close-up diopters (these are cheap)
2) extension tubes (simple hollow barrel that goes between lens & camera body - it has no lenses in it. It's sole job is to hold the camera lens farther away from the camera body, which naturally shifts the whole focus range closer and also somewhat magnifies the view. They do have electronic contacts to pass the communication through between camera & lens.) But they tend to be inexpensive.
3) reversing mount - this lets you mount a camera lens "backwards" so you can use a normal lens as a close-up lens. But for most of these, you lose control of the aperture.
4) get a "true" macro lens that can shoot 1:1 scale. This tends to be the most expensive option, but offers the most versatility, control, and usually also the best image quality.
Focus-rail:
You may actually want to pick up a "focus rail" for a tripod depending on how you shoot. If you use a shallow depth of field, then it wont be possible to get the entire object in focus at the same time. One technique is to use "focus stacking" where you take lots of images... but nudge the focus very fractionally so that different parts of the object are in focus. Software is used to combine the image and you get a final shot with everything in tack-sharp focus.
But there's a problem... most lenses "breathe" when you adjust focus. This means the angle of view at close focus distance is NOT the same as the angle of view at maximum focus distance. That shift in angle of view means the images don't stack the way they should.
The idea behind the "focus rail" is that this is a rail that attaches to the tripod and you mount the camera on the rail... and rail allows the entire camera to slide forward or backward along the rail WITHOUT changing the focus on the lens itself. So you're moving the whole camera to focus instead of adjusting the lens. Because you do this, the angle of view isn't actually changing.
This is really only an issue when using a shallow depth of field. But when you have very close focusing distance, depth of field generally is shallow. So you may want to shoot your jewelry at say... f/16 or above... just to deal with the depth of field issues.
