Photographing prints
Jesse11
hi, What is the best way of getting a good overal natural looking photo of a print, my attempts at using flash with a diffuser still gives me an uneven result
this is out of my usual photography comfort zone, would anyone have any suggestions??
thanks
Jessy
Bossy
Shot it at a 45 degree angle or bounce your flash.
dxqcanada
Woodbridge, Ontario, Canada
Diffused sunlight is not bad ... nice cloudy day.
Bossy is correct when using flash ... lights at an angle.
480sparky
Chief Free Electron Relocator
Supporting Member
Iowa
Website
pixels.com
Will the print fit into a scanner?
KenC
Philadelphia
Yeah, sometimes a scanner is the best camera!
Otherwise, I agree with dxq about window light on a cloudy day.
MReid
Boise Id.
Website
www.alloutdoor.smugmug.com
As mentioned diffused, window light works really well.
Make sure the photo is square to the camera, and that both are on solid rests.
Big Mike
I am Big, I am Mike
Staff member
Supporting Member
Edmonton
Website
www.mikehodson.ca
Window light can be useful, but not ideal. You want to make sure that your piece (art/print etc.) is lit evenly. If you have a window that is closer to one side than the other, the inverse square law comes into plan, and you will have more light reflecting off of one side, than the other.
As mentioned, you need to get your light source away from the camera. Reason is that most prints will have some aspect of direct reflection (imagine that they are somewhat like a mirror). So any light source that is inside the 'family of angles' (something you would see in the mirror's reflection), will show up as glare on your photo. So by moving the light outside the family of angles, you take the glare away. Also, make sure that any light source is not in your family of angles (a window behind you, for example).
But by moving the light outside the family of angles, you run into the problem I mentioned above, with one side being brighter than the other. So you'd want two equal lights, one on each side. I would think that all of this is in the book that KMH mentioned.
(I really have to read that book, one of these days).
KmH
In memoriam
Supporting Member
Iowa
Website
kharrodphotography.blogspot.com
Yep. It is.
The book discusses the 'family of angles' and the book covers product lighting as well as portrait lighting. All of which is why it is in it's 4th edition.
