Playing with Lighting
eccs19
Lisle Ontario Canada
Still learning my lighting techniques, so I played for a bit tonight. Couple of mistakes I did, I didn't need my ISO so high, and had +1.5 compensation. (wasn't needed as I shot all manual) How does the lighting look? Flash was camera left with some natural light coming in from the right. Also had reflector on camera right. (first image only) Second shot I had a flash behind him just to try out, but no reflector on that one.
Camera Maker: PENTAX
Camera Model: PENTAX K-7
Lens: Tamron AF 17-50mm F2.8 XR Di-II LD
Image Date: 2011-08-13 19:16:22 -0400
Focal Length: 45.0mm (35mm equivalent: 67mm)
Aperture: f/5.6
Exposure Time: 0.0056 s (1/180)
ISO equiv: 400
Exposure Bias: +1.50 EV
Metering Mode: Spot
Exposure: Manual
Exposure Mode: Manual
White Balance: Manual
Flash Fired: YES
Photographer: MARK EVERS
Copyright: MARK EVERS
Image Date: 2011-08-13 19:10:41 -0400
Focal Length: 50.0mm (35mm equivalent: 75mm)
Aperture: f/5.6
ISO equiv: 400
Metering Mode: Spot
Exposure: Manual
Flash Fired: YES
If you are learning lighting techniques you should check with a free book or PDF file online that illustrates good lighting techniques then try to duplicate the setup. Personally I think your lighting should be a little more subtle. The spotlight on the back of the kids head has blown out his hair around the edges and at the same time the front is too underlit in places.
