qleak
- Joined
- Dec 11, 2013
- Messages
- 629
- Reaction score
- 183
- Location
- Ohio
- Can others edit my Photos
- Photos OK to edit
Disclaimer: Apparently I'm dead wrong in many of the things I say below. Proceed with caution
I love my crop sensor D7100. That being said I'd like to address some common misconceptions people have about crop sensor cameras. I'm not trying to pick on anyone, I've even probably thought, said or typed some of these myself. I wonder how much of this is me trying to rationalize the pot of money I set on fire for my photography gear.
Here's the one that is prevalent:
"Crop sensor cameras have extra reach"
This unfortunately is utter nonsense. Suppose you have a crop sensor and a full frame sensor from the same generation and manufacturer with roughly the same pixel density. See the diagram below:
There will be a copy of the crop sensor inside the full frame sensor. All you have to do is crop the photo. Get it? That's why it's called a crop sensor.
Some cameras even have a mode to do this that discards the outside of the frame to save space. If you're lucky they'll even have a viewfinder mode to help with the composition. But that's all it is, saving memory space. If you can't afford memory cards what are you doing in photography?
Some people would argue weight is an advantage of crop sensors, and there is some truth to this too, but is a ~100g difference really that big of a deal? You're likely to be putting much more weight into lenses and lighting equipment anyway!
You might argue crop sensor lenses are lighter. If you are a sick perverted individual you can use crop lenses on FF bodies anyway. All you have to do is crop the image or just deal with black parts of the frame.
Some other supposed advantages of crop sensor and my criticism:
Being in photographer, especially if you want to do it professionally, is about managing your expenses. That's why we're not all running around with digital hasselblads or phase one cameras. Most of us don't need them enough to justify the cost.
I may need some popcorn for the responses to this
- Higher frame rate (what are you doing spraying and praying? It's not even an advantage if you go to the pro line.)
- Higher flash sync speed ( not always true. but congrats anyway you may gain 1/3 EV)
- Deeper depth of field (nope just crop a FF image and you have exactly the same).
- Better (or worse) bokeh ( this is a property of the lens, aperture, focal length and focus distance. If it's in frame it will be the same)
