Gary A.
It is all about harmonizing with your equipment. The 35mm hasn't any more special magic than a 50mm or a 28mm, et al. By sticking to one focal length and one camera you will, (hopefully), harmonize with the lens and camera. The lens will become an extension of your eyes and the camera an extension of your hands. After a fashion you'll intimately know how that focal length captures an image. You'll see that 35mm image or that 50mm image even before to look through the viewfinder. Your fingers will semi-automatically adjust the shutter speed or aperture or ISO to reflect the image you see in your mind's eye. This intimate knowledge of the camera, knowing where your adjustments are by feel ... semi-automatically making your adjustments, allows more brain power to focus on your subject. Using only one focal length forces you to be creative. Every time you shoot, you should look for and attempt to capture the exceptional image. Using only one focal length not only teaches you the limitations of a particular lens but also allows you to see how high you can fly within those limitations.
Much of photography is a craft. You have a learning curve. The more you shoot, the quicker you'll travel up that learning curve and the better you will become. Starting out with multiple focal lengths and multiple lenses extends the learning curve and dilutes your ability to harmonize. Add lenses and new equipment over time. Concentrate using your new equipment until you have reached a level of intimacy where you can precisely see an image at a certain focal length with certain settings.
Good Luck and Good Shooting,
Gary
PS- GAS is a lot more fun than harmonization.
G
Gary
G
