SamSpade1941
- Joined
- Jul 17, 2012
- Messages
- 491
- Reaction score
- 65
- Location
- USA
- Can others edit my Photos
- Photos NOT OK to edit
I think the argument about primes held a lot more weight in the older days when zooms really were, at a technical level, worse than primes for performance. These days we've amazing zooms which can perform fantastically well - well enough that they significantly reduce the advantage of primes (at a technical level).
As for the argument of primes making you a "better" photographer. Eh the main argument there is that the prime removes a layer of choice and thought, which is what focal length to use. Primes give you one focal length, so you've got no choice unless you take the longer process of changing lenses - and if you're using more than one prime at an event chances are they'll have big differences in their angles of view so its really a clear choice as to which would suit best for a given shot.
This removal of a thought process essentially forces one to frame the shot with their feet, not with the zoom (honestly I doubt either approach is any more pure or perfect than the other) and it also means that since you're not shifting the zoom around youre able to devote more attention to the scene.
It's one of those things that, as you gain more experience, become a lesser issue as more of the cameras operation shifts to the back of your mind as second nature.
Also don't forget many that advocate primes grew up with primes; in their day zooms were bad (or at least worse than to a significant level). So many spent a greater part of their photographic experience shooting with primes. Just as many dislike the angles of view that crop sensors give; many dislike using primes - its not a "this is better than that" its a case that they are more comfortable with what they know and grew up with.
Prime VS zoom - in the end its really going to come down to you; your budget, your situation, what and how you like shooting etc... Put your criteria on the table and see how things line up for you. Heck if you want you can always use a zoom like a prime, just don't touch the zoom control.
I agree with this totally. Almost all zooms used to be totally wretched, the only one I found useful at all for many years was the Nikkor 43-86 and it was prized by many photographers because it actually had good glass and worked reasonably well. Most other zooms not so much. When I returned to photography my budget would not afford me buying several primes as I had in the past and I was forced to purchased to Nikkor Zooms an 18-55 and a 55-200. Both have done nothing but surprise me with their image quality. That was not my experience in the 80's and Early 90's for the most part.
