Learn the Sunny 16 rule -- it's a great baseline.
While I don't know what the light was like at your particular waterfall, I can make some assumptions that wont be far wrong.
The Sunny 16 rule says that the exposure for anything shot in the middle of a sunny day is f/16 with the shutter speed set to the inverse of the ISO sensitivity. That means ISO 100, f/16, and 1/100th sec would work. But that's not the exposure you use... that's a baseline. All "equivalent" exposures are also valid. If I open up the aperture by 1 stop, I can halve the shutter time... etc. The rule even goes on to say light overcast (or light shadows) eat about 1 stop of light (you'll know it's a "light" overcast because you can still quite clearly see your own shadow.) Medium eats 2 stops (your shadow fades and usually can't be seen) and heavy overcast eats 3 stops (and the clouds are dense enough that it could look like it's going to rain.)
If this waterfall was in shadow full shadow we might be losing 2 stops of light.
You want the slowest shutter speed you can manage. In bright sun, you could go to f/22 and slow the shutter to 1/50th (which is still too fast). If it's in medium shadow (2 stops) you could slow your shutter speed to one quarter of that (1/13th). That's still a _bit_ faster than we'd like... but we're getting close to slow enough speeds. You could wait until evening (or early morning) and take the image with a dusky sky or sun very low in the sky. You could wait for a cloudy day.
Or you could get a 3 stop ND AND stack your circular polarizer (CPL) with it (everyone should own a circular polarizer -- so if you don't have one of those, go get one.) A 3 stop ND (a "0.9" filter because a "density" level of .1 = 1/3rd of a stop. so .3 is actually 3 "thirds" or 1 "full" stop and a .9 is three full stops. A circular polarizer blocks a variable amount of light because it's selective about the polarity of light which is allowed to pass. BUT... it generally is able to block about 2 stops. That means a 3 stop ND stacked with a CPL is about 5 full stops. That would let you take your f/22 exposure at about 1/2 second... even if it's in full sun at mid-day. If it's not in full sun you could be at 1 full second... maybe even 2 full seconds.
You will want a tripod and either a remote release or use the delay timer so that the camera doesn't shake when you activate the shutter.
