Profoto B1
griffin86
Canada
Pretty neat idea, I was thinking about one, but then I saw the price. 1800 euros I believe. Well I am still considering it, depends if I can HSS with it.
Please do not post images to which you do not hold rights. You may post a link.
Specifications
Maximum power: 500Ws
Control range: 9 stops (2-500Ws)
Control Levels: 1/10 and 1/1 stops
Recycling time: 0.1-1.9 s (Quick burst of up to 20 frames / s)
Modeling light: 20W LED (70W equivalent)
Functions of the light setting: off, proportional, selected freely (5-100%)
Operating mode: Freeze (shortest flash duration) or normal (high Farbstabilität)
Burn times: Normal (t0, 5): 1/11.000 s (2Ws) to 1/1.000 s (500Ws) Freeze (t0, 5): 1/19.000 s to 1/1.000 s (500Ws)
Leistungsstabilität: Normal + -1/20 Aperture flash to flash; Freeze + -1/20 Aperture flash to flash
Farbstabilität: Normal + -150 ° C full scale / 20 K of flash to flash; Freeze + -800 ° C full scale / 50 K of flash to flash
Guiding shield (2 m, ISO 100, Magnum Reflector): 45.2
Power supply: Replaceable Li-ion Battery 14,8 V/3Ah
Battery capacity: sufficient for 220 flashes at 500Ws
Synchronization and control
Synchronous Connection: 1 (3.5mm mini-phono, conforming to ISO 10330)
Photocell power: available
Funksyncronisation and radio control: built-in Profoto AirTTL receiver (required: Profoto Air Remote TTL as Extrazubehör)
Wireless range: up to 300 m
Other
Display: Multi-function LCD
Active COOLING: thermo controlled for during biking small Geräuschentwicklung
Ready signal diode, dimming, sound
Auto dumping: yes
USB: Yes, Mini USB terminal is designed for firmware updates
Quick burst: up to 20 frames / s
Dimensions
Size: 31 x 14 x 21 cm
Weight: 3 kg including battery
