Quick Mini Session
412 Burgh
Pittsburgh
Alfonso by ZDiBeradin, on Flickr
Alien Bee to the models right side. About 1/16th power. Beauty Dish 22 with sock.
I personally like this one, lets hear what you pros have to say! :hail:
IMO, your modifier was too small. A BD is really either for fill or lighting a small (headshot) type image. To light a full body portrait (even though he's crouching) I would have preferred a 36" or larger SB. As for the pose... to be blunt: I think it's awful; a variation on the classic 'taking a dump' pose.
I also think a SB would do better for the body size picture. As for the pose I have the impression that his not comfortable, as in I'm doing this only for this photo. And to be picky, I'd like to see a bit more on the right side of him, maybe a reflector!!
Unfortunately that's all I'm limited to for a lighting modifier. I have been looking into something else that helps for full length portraits. As well as getting my SB-700 synced with my aleinbee (if possible)
...Unfortunately that's all I'm limited to for a lighting modifier. I have been looking into something else that helps for full length portraits. As well as getting my SB-700 synced with my aleinbee (if possible)
Bull****!!!! Go to Wal-mart, Michaels, or where-ever and pick up a 2x4 sheet of white posterboard or foam-core. Use mechanic's wire to make a shallow convex curve in it and fire the AB into that just like a reflecting umbrella! That will give you a nice, big, soft light and cost all of <$5! It might look a little "Ghetto", but it will work. There should be no problem syncing your speedlight and ABs... just means getting another trigger. A four pack of Cactus V5s should run <$100 and will do nicely. You could also get an inexpensive optical slave from FlashZebra, or, trigger the speedlight and use the optical slave on the AB... LOTS of options.
Unless there is a campfire or a traditional old-world, coal-fired forge, or a wounded infantryman laying in the foreground, the crouching pose is not so good...just sayin'.
I do not mind the light modifier's basic effect in this shot, but his shirt does look a bit too "hot" on the front, and burned out a little.
yeah, my posing ideas are next to none :confused:
Much better. I'd do a little burning on the shirt, and maybe dodge the hair just a tad. A shame about the cropped shirt-tails.
I actually like the first one better. I like the urban feel and the textures in the back round. I don't mind the pose. Not sure if you are using PS or LR but I would bring down the exposure around his shirt and face a little and play up the shadows a bit to give it more of a dramatic feel.
Thanks for all the input. If I want to continue doing full length portraits with one light... what is the most useful light modifier? I'm assuming a soft box.
There is no one "best" modifier, but my current favorite is my 60" brolly-box. For 'on-the-road' work, I have a 30" Lastolite Exybox which works very well with a speedlight. That and a 72" light panel on the off-side work very well.
