Shooting a landscape and including the stars is a balance between a long shutter and the movement of the stars themselves. The rule of thumb is that you can leave the shutter open for (600 / effective focal length) seconds, before the points become trails. So if you were using a 24mm lens on a full frame camera, you could use a 25 second shutter. Getting the stars to show up in such a short amount of time usually means shooting with the lens wide open and at a midrange ISO, which will put your equipment to the test. I've shot stars effectively with a 15 second shutter, at 28mm f/1.8, and ISO 800. How fast your lens is, and how well your camera performs at high ISO will be the limiting factors.
If you're not concerned with freezing the stars' motion, and instead want to take star trail shots, the idea is to leave the shutter open as long as possible (or even stack multiple long exposures (to cut down on noise and sensor heat)). Star trails are much less equipment intensive than point stars. You can stop down to f/4 or f/5.6 for sharpness, and shoot at base ISO. Then just expose for as long as possible, it will take some experimenting to determine how long your camera can go before noise becomes a problem. Be sure to enable "long exposure noise reduction", or equivalent.
