Raw vs JPEG
bs0604
Virginia
I am relatively new to photography and HDR & thus my question is probably basic knowledge. I was reading an HDR site which said you should shoot the bracketed photos in RAW and then save to your computer as JPEGs and then upload the JPEG pics to Photomatix to process. Why would you want to change the RAW to JPEG prior to putting in to Photomatix? And I would think that shooting in RAW and then saving to the computer as JPEG would negate the advantage of having shot in RAW in the first place?
I haven't used Photomatix in a while but I don't think it will read RAW files.
I just started doing HDR and using Photomatix a couple of days ago but as far as I know I have been shooting in RAW and staying in this format while uploading to Photomatix. (Acutally it is NEF which I believe is Nikon's RAW equivalent)
Could be. Like I said, it's been a while.
I will mention that Nikon doesn't always release the full file structure details of their NEF files so some RAW converters do a much better job than others. If you have one that will do it right that would probably be the best way to save your files. Also, save the files at minimum compression or use TIF for the best quality. JPEG can be a very lossy format.
You are correct. You will always get way better results feeding RAW source files into your HDR s/w. Severe image damage often occurs when converting a RAW file to a jpg. Huge changes occur even moreso to the images in the bracketed set which are at the extremes (overexposed and underexposed). Always input RAW files. All HDR apps read RAW files and most keep the s/w updated to accommodate the latest DSLRs.
Regards, Murray
Photomatix has a built in RAW converter unless it is used as a Plug-in to Lightroom or Aperture where it will use the Host application as the RAW converter
Nik HDRefex Pro requires a Host program
And yes, use the RAW's not Jpegs
I don't think photomatix is a very good RAW converter, I think it works a lot better as a plug in to Aperture. Though I don't think that has anything to do with whatever reasoning the source you quoted gave for converting to JPEG.
I didn't even realize it could be used any other way nor would i want use mine any different than with Lightroom3
Assuming I upload my bracketed images to Photomatix in RAW, should I then save the final processed HDR image as RAW or JPEG?
I believe it's shoot in RAW -> merge to HDR -> save as JPEG.
I accidentally shot bracketed photos in JPEG and when I used PS: CS3 to merge and edit as HDR, when I tried saving, it would only let me save as .PNG. Anyone know why? Does it matter between PNG and JPEG?
The image AFTER tone mapping can only be saved as a 16 0r 8 Bit Tiff or a JPEG, Before tonemapping (32 bit image) can be Saved as a Radience HDR file.
If the image is in 16 bit Mode, you can't save as a JPEG, to save as a JPEG go to Image> Mode> 8 bit and then you will have the option to save as a JPEG
