- Joined
- Mar 8, 2011
- Messages
- 25,393
- Reaction score
- 9,148
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
same rate as what? A free falling person who just jumped off the cliff with no wings? He's descending at a substantially slower rate than someone free falling because he's converting so much of his downward energy into forward energy via wings + wind resistance. If he wasn't slowing his rate of descent so much, the only forward energy he would have had was what he got in his initial leg jump, which was about 8 feet. He landed what looks like several thousand feet away from where he jumped.
No, he's falling at the same rate as if he jumped with the suit and made no attempt at forward motion.
This is the same as the old "Fire a bullet out of a gun the same time you drop one" puzzler.
No, because the bullet has lots and lots and lots of forward energy to begin with. Not the same at all. His only initial forward energy is from his legs. And unless he's some super freak of nature, he couldn't have jumped outwards several thousands of feet.
Think about it, the whole reason the bullet falls at the same rate regardless of being shot or dropped is because the downward energy is the same, but the shot bullet has a lot of added forward energy via the gun.
Energy isn't free. Unless you're claiming he was shot from an invisible canon, that energy came from somewhere that hurled him forwards thousands of feet. It came from converting his downward potential energy into forward energy.
It's like you don't fall at the same rate going down a slide as you do if you jumped off the top, even if the slide was purely frictionless, because the slide is converting some of the downward acceleration into forward acceleration.
Um,.......... wrong!
They will hit the ground at the same time.
And the same principle applies here. If he jumps, then falls perfectly straight down (with his suit deployed just like he does in the video), he will descend at the same rate as he is in the video. Heck, even some old geezer by the name of Isaac Newton knew this.
