I use a combination of a quantum pack, energizer 2500s, and energizer lithiums. the quantum pack is the most reliable in terms of recycle, but they can kill strobes so you have to watch it, as JerryPH said. I like lithiums for shooting events (like dark clubs or shows) they recycle slightly faster than the rechargable AAs, and are half the weight. the 2500s are for when what I'm doing isn't overly important or as a backup.
OK guys, someone is going to have to explain this to me. How does a battery with lower voltage than a standard battery, "Kill" a strobe? I can understand if the user, fires the flash too fast, because the batteries allow them to kill the strobe, but this is abuse by the operator, not the fault of the battery. Anyway, someone explain it to me please.
I can tell you that with a NiCad or others if there's a short, they will melt the wires and possibly start the flash on fire, but that's not using the normal charging circuit, it's a dead short. Do they still make NiCads?
I've used rechargeable for years and saved loads of money by not having to buy new batteries every week. I just ran my three sets of four that I use in the slaves, just because I had some time. They do leak down. I also number them or color code and run them in matched sets.
Mixing old and new is just as bad for standard batteries as it is for rechargeable. The weaker batteries will draw from the good ones and make for shorter life of all. The weak batteries are charging from the good ones and stealing voltage.
Quick chargers will shorten your battery life because they heat up the batteries. Heat is the enemy. Slow charge except when necessary.
Rechargeable will run at full voltage 1.2-1.3v up until they are 96% dead and then suddenly go away. Standard batteries will slowly lose voltage from 1.5v as they get older. That's why a rechargeable suddenly stops cycling your flash and the standard batteries will just get slower and slower.
When they get old, I use them in TV remotes, flashlights and radios that don't demand the current that a flash does. That's only for people who want to pull the batteries out of their remote every six months and re-charge them. :thumbup:
Finally, Lithium have no liquid electrolyte means they are immune from leaking!
