Red Berries
The certainly are red. They look a bit lost in the center there. Maybe crop in a bit and change their position in the frame instead of bang in the middle.
Cropping would make it better. Thank you for the suggestion. Maybe a little off the bottom and right side?
Thanks for the identification Jeff. I searched several different ways and couldn't come up with anything. It is along the edge of a wooded area. I'm east of the Mississippi so I'm probably on the edge of it's territory.
It's mostly found in the wilderness areas in the Eastern US.
You are welcome! I by no means know all this stuff. :) I use apps like iNaturalist Seek, which is fairly accurate. Green Dragon are often found in the same area as Jack-in-the-Pulpit, so keep your eyes open.
If it were me, I'd crop a wee bit off the top and a slice off the left to have the berries facing down into the frame. It's your photo mind so only a suggestion. It often helps to get the subject of a pic off center (not always). Just tinker around until you like what you see.
Thanks for the help. I'll play around with it.
