jcdeboever
- Joined
- Sep 5, 2015
- Messages
- 19,860
- Reaction score
- 16,082
- Location
- Michigan
- Can others edit my Photos
- Photos OK to edit
Rest area along an interstate.
The sabattier effect? The image was horrible because I was too far away and took it with an outdated Digital Point digital point shoot. I seen something in it so I got to work on it. Using Gimp, I converted it to black and white, removed the noise, and made a slight crop. I believe I straightened it a little as well. My last step I applied a 3200 ISO film plug in. However, between the crop and plug in, I used the technique in this link The Sabattier Effect - Digital Photography SchoolQuick smoke on the edge of bench. Ha.
Curiously looking picture. Very soft, impressionistic look like shot with some soft filter of very strong action. Interestingly the contour of the shirt on the back of that man displays something, what in film photography would be called Mackie line. And there are other things.
How did you get it ?
Well, I am a film photographer...Interesting that you noticed that.
If you interested in Sabatier effect check out works of Man Ray.
However Mackie line could be obtain chemically. Crawley FX1 formulation is using potassium iodide to get Mackie line without the need of partial solarisation. Your picture resembles more that, than full Sabatier effect.
That is neat. I ordered some developer and fixer, should be here next week. Still hunting for a reasonable priced scanner. I found my recipe book. My Kodalith 6 ASA film arrived yesterday, 5 rolls. Still can't locate my home made cartridge opener, probably will order one. It's slowly coming together. My K1000 patiently awaits.I didn't play for long time with Sabatier effect. Reason is very simple, not every paper responds well and Ilford RC papers are especially bad. The "rule" here is, that paper should be slow. But I have one totally accidental Sabatier effect made on film, it has completely natural, perfect Mackie line. I hope you won't mind me showing it in your thread.
We used to simply rip open the cassettes with our fingers and peel back the opening to expose the film. Typically, it is hard to lose one's fingers.That is neat. I ordered some developer and fixer, should be here next week. Still hunting for a reasonable priced scanner. I found my recipe book. My Kodalith 6 ASA film arrived yesterday, 5 rolls. Still can't locate my home made cartridge opener, probably will order one. It's slowly coming together. My K1000 patiently awaits.I didn't play for long time with Sabatier effect. Reason is very simple, not every paper responds well and Ilford RC papers are especially bad. The "rule" here is, that paper should be slow. But I have one totally accidental Sabatier effect made on film, it has completely natural, perfect Mackie line. I hope you won't mind me showing it in your thread.
Litho film. Seems like very good idea. How you gonna use it ?
