Rings
tecboy
San Jose, Cali, The Heart of Silicon Valley
I can barely see the rings. Any explanation? Is my camera damaged?
What rings are you talking about? I don't understand the question.
I can see them.... lots of concentric rings centered in the frame. Did you do any post-processing or is this SOOC?
BTW, next time, use some bull-nose tiles.
If you click on the image, it will enlarge it and you see multiple rings.
480sparky, Ummm...I'm still a beginner. What is SOOC and bull-nose tiles?
I set the shutter super slow about 30 second and take a shot in a dark room with little light. Just for fun. Hopefully I didn't damage my camera.
No, your camera isn't damaged. It's an optical aberration.
I'm guessing those rings are caused by the the lens cement used to join some of the internal lens elements. Particularly if the lens used was a kit lens.
What lens was used?
I'm guessing those rings are caused by the the lens cement used to join lens elements.
What lens was used?
It is interesting you said that. I use a wide angle lens 18-55mm. When I use a telephoto lens, that is 55-250mm, I don't see concentric rings.
SOOC = Straight Out Of Camera (no computer processing).
Bull-nose tiles have a curved, finished edge instead of the flat, unfinished edge you installed.
Yeah, I see them now. I didn't zoom in far enough previously.
Thanks guys. Turns out to be a lens filter causing these rings. That would be intriguing photograph with concentric rings.
Good call, Buckster! The voice of experience, eh?
