Yours even more magenta, however love how gentle you went with the processing (except the
Lacking a defined white, black or gray reference point, any adjustment to WB was a guess at best. I tried sampling the white of the eye and the pupil, which pulled the image to far to the cool side which in reality may have been closer. The other factor is hue being a function of luminosity, makes having a good exposure up front important to color rendition. I have a library of RGB skin color settings that I refer to if I'm really in need of drastic change, but most times I shoot for a pleasing look by eye, as on this.
As to processing the only real adjustments in Lr other then raising exposure, and shadows, was to set the WB, decrease highlights, set the white and black points and apply a mild contrast curve. Once I'd made these adjustments there were only a few minor blemishes left for the spot removal tool. I used the lite skin softening tool to brush the skin lightly and the shadow tool on her right cheek to define the cheek bone. Most the brush work was on the hair to the right to even out the color from the hot spot. After that an ND gradient from the left to pull down the spill on the background and a radial filter to isolate her more from the background. Never touched the denim.
Your basic image was good, very well composed, and you nailed the focus on the eyes, so no sharpening anywhere required. Again, just my opinion but I believe raising the lights, bringing them just a little more toward on camera axis and balancing them for 2:1 ratio, moving her forward slightly from the background, and adding a kicker on the hair, would have done much to highlight the features.
