Googled it... found this site.
Bird Identification :: Bird Watcher's Digest.com
Based on that I would guess it was one of these.
https://www.google.com/search?q=Blue-headed+Vireo&client=firefox-a&hs=UEY&rls=org.mozilla:en-USfficial&source=lnms&tbm=isch&sa=X&ei=2nhsUZTVOIOr2QW6oIGICQ&ved=0CAoQ_AUoAQ&biw=1024&bih=618
Not on the photo, but for the photographer, don't be afraid to bend your knees.Any comments on the photos?
I still recommend that you stop centering your images. All three of them are dead center. Let them look at the center of the image, not be the center of the image.
Also you needed more depth of field to get his beak in focus. The eyes are perfect, and that is the preferred point for sharp focus, but it works much better when the entire face is in sharp focus.
Here's a Hummingbird from a similar angle. I focused on the eyes also but made sure I had enough aperture to get the entire head in focus. I think it makes a big difference.
I love your hummingbird shot!! Yes, your edit is much better off to the side a little. Gah this is my weak spot. I'm so bad at off centering.
Do you prefer to not shoot in aperture priority? That's what I did.
Perfect explanation. Thank you.I love your hummingbird shot!! Yes, your edit is much better off to the side a little. Gah this is my weak spot. I'm so bad at off centering.
It varies. I shoot in aperture priority most of the time, but shoot in shutter priority or manual when the shot needs it. Generally it depends on what aspect is more important, holding a shutter speed or holding an aperture or holding both. Still birds, wildlife that isn't moving fast, things like that I use aperture priority because I'm more concerned with the depth of field. Birds in flight, motorsports, anything fast-moving I use shutter priority or manual because I need to know that my shutter speed isn't getting too slow.
