PatrickJamesYu
- Joined
- Aug 30, 2011
- Messages
- 214
- Reaction score
- 9
- Location
- Los Angeles, CA
- Can others edit my Photos
- Photos OK to edit
Cool shot. This is the camera and lens that you used...
Camera: Nikon D90
Lens: AF Zoom-Nikkor 28-80mm f/3.3-5.6G
Shot at 28 mm (35mm film equiv: 42mm)
Exposure: Manual exposure, 1/800 sec, f/3.3, ISO 250
Flash: none
I'll try that, thanks!Action looks fine, but a tighter crop would have made this a much better image.
You can download a picture to your PC and go to this link Jeffrey's Exif viewer and browse to the photo and then check the info...Cool shot. This is the camera and lens that you used...
Camera: Nikon D90
Flash: none
Sweet
What's the plug-in called again for that?
Thanks!
Thanks for the tips, but be careful where?Also, be careful when you add soft-focus or gaussian blur in post.
+1A key element in action/sports photos is getting the faces. The face shows the expression and tension in the activity. For this shot a good spot to shoot from would have been about 45 degrees off to camera left of that step and about 15-20 feet away, on the ground shooting up at him. This angle will most likely also eliminate background clutter. Shoot tight, on a composition like this where the subject is such a small part of the image it is easy to loose a viewers attention and show too much distracting background. If you choose to compose a shot like this, then at least get him out of being right smack in the middle of the image. Crop off the right side maybe using the edge of the step as your guidine, this gives the appearance of action and room for the subject to move into.
