Skateboarding - Stalefish air
if you have any strobe try using them next time, for some reason the WB seems to be pretty green tinted, was that done in post? my other suggestion would be get a bit closer with that fisheye... other than that great timing
If it can be take closely then more descent looks get. The capture timing is great .
Thank you
I wish you were lower to put him above the horizon line, right now he's almost swallowed up by the trees and my eye drifts away from him to the group dark people standing on a light surface, them and the black sweatshirt on the ramp.
Thanks for the inputs. It was so hard to take this picture because he was going so high, and as you can see the ramp is seperate from the rest of the ramp so to get closer i'd have to stand on top of that ramp which would be a whole diffrent angle pointing straight down which I didn't really think of doing at the time. The WB was done in post its an action i made. I probably should stop using it and use my strobe, i'm just not great with flashes. Here is the original
trust me once you learn to use your strobes to light your subject your photos will come out more crisp. And you can't learn how to use them without practice!!
ps def like the wb in the reply better.
