SOOPAH PUMPED! New 430 EXII picked up!
ceejtank said:
How did you configure this? Was it a setting on the flash or on the camera?
Both. Open your built in flash to activate flash mode. Turn on 430ex, and put into slave mode (no this isn't optical slave). Go to flash menu on camera. Go to on camera settings. Should be three settings. Choose the one that indicates external flash only. There's other options for using both on camera and external, and also to choose ratio between two sources. Once that's done you're all set. I used my flash manually so changing settings on the fly was awesome. Again you need to make sure the 7d has same functionality. I would do a quick Google search or refer to your manual.
Awesome. I'll do that.
A video I found that shows the steps listed above.
