You basically can't upload a RAW file to any image share website, you need a file share system because a RAW isn't an image but a data file. That said from the crosses they appear to be dead pixels. That you can see more on the RAW and less in the JPEG means that the auto editing in the camera is either removing or masking them.
As Tinderbox says you want to look at the pixel mapping feature in your camera manual (most are online if you've lost it) which should be able to run you through how to take a photo and have the camera scan and auto edit out the bad pixels. I'm not sure but dust-delete "might" also remove them or be bundled with the pixel mapping (I've never done a pixel mapping to really know).
As a point the only thing I know that can cause dead pixels is a laser beam going into the lens, especially whilst shooting video. Something that people shooting at clubs/concerts have experienced with those spinning laser shows. I'm sure there are other things which can cause dead pixels but I've never had the issue to look into it in any great depth. You've quite a few though so it might be prudent to look into common causes as you could be doing something regularly that might be contributing to the problem.
As they are only 1 pixel in size once they are mapped out they shouldn't be an issue.
