CrashC
- Joined
- Feb 19, 2011
- Messages
- 5
- Reaction score
- 0
- Location
- Kailua, Hawai'i
- Can others edit my Photos
- Photos NOT OK to edit
I've read many of the previous threads discussing the inability of several web browsers to process color profiles, thus blowing up colors in photos posted on the web.
My workflow:
Capture in RAW .dng. Open in LR on Macbook Pro (circa 2007) OSX 10.5.8, post process as needed. I then either:
a) export directly from LR to sRGB jpg
b) from LR, "Edit in Photoshop CS5" with sRGB set as Working Space, modify image as needed, then save as jpg with sRGB embedded.
This is the best approach to have my images appear correctly to the most web viewers, correct?
When I post the images to anywhere on the web and view on my Macbook Pro, these are the results:
When I view the same images on a PC (sRGB LCD laptop monitor), these are the results:
Since I've read Firefox and Safari for PC should process color profiles and thus display my images correctly, that makes me think the PC's monitor just isn't color calibrated. That lead me to view the images in Firefox on two different PCs, both of which showed the same inaccurate (desaturated in this case) colors.
The only variable here I can think of that I'm not getting my head around is if my Macbook Pro's monitor is a wide gamut and all of the PC laptops I tested are standard sRGB. Just a hunch.
Any idea why Firefox and Safari for PC wouldn't be processing color profiles properly? Also, is the above workflow what you use for web posting as well or is there a better solution?
Thanks in advance for any time spent here with my issue. It is appreciated.
My workflow:
Firefox displays colors correctly
Safari displays colors correctly
Chrome desaturated
Chrome desaturated
IE9 desaturated
Firefox desaturated
Chrome desaturated
Safari desatured
Firefox desaturated
Chrome desaturated
Safari desatured
