I'm showing two images that I took recently.
The first is a stack of 31 stills (ISO 800, 24mm, 30 sec, f/4.0) using the freeware "Star Trails" (
Startrails application). Each photo was shot with the long exposure noise reduction on (which means for every exposure, there is a corresponding dark frame), which is why the trails look like they have gaps (the gaps are the dark exposures). Those setting enabled me to reach stars of magnitude 8.0 (at a time when naked-eye visibility was around 5.5). Noise reduction was applied to the individual frames prior to stacking, and a final noise-reduction pass was made after stacking. My camera is the Canon T1i, which is not particularly good at higher ISO levels.
The second image is 1 still (ISO 800, 10mm, 301 sec., f/4.0), showing the amount of skyglow recorded with a 5 minute exposure.
The second image makes it clear that to try and get star trails with a long exposure is doomed to failure, with skyglow rapidly building up and ruining the image. The solution is to use relatively short exposures to minimize skyglow, and then stack them to achieve the star trails.
The alternative is to find true dark sky locations which allow much longer exposures before skyglow still ends up showing up.
Sky location I used was found using this site (
Dark Sky Finder). Sky transparency, etc. can be found here: (
Clear Sky Chart Homepage).
