Studio Lighting...Help
kozment
Ok, I just got in my home studio lighting and I am having some issues. It seems that the shadows of all my pics are really grainy, if I zoom in with my Photoshop program they look like sand paper, I can fix it in Photoshop, but it takes a lot of work, anyone have any suggestions....Thanks
What are your specs? Do you have an example for us? Studio shots should't be grainy.
shoot at 100 iso.
I've already fixed this on but maybe it will give you some idea
Nikon D3400
f/5.6
1/100 sec
iso 4500
focal length 55mm
Nikon D3400
f/5.6
1/100 sec
iso 4500
focal length 55mm
Apparently your camera doesn't do ISO 4500 very well. Go down the scale quite a bit.
Well, to be honest, I don't know. I was using the aperture setting on the camera and that's where is set the iso. I guess I should have mentioned, this was the first time using this camera also. I'm learning, so what should the iso be for studio lighting?
I am a true beginner, so be patient..lol
The ISO for studio work should be <200. First, are you actually using studio lighting (moonlight or pack & head strobes) or are you using some cheap 'Cowboy Studio' style MiC PoS continuous light source?
That'll be your problem right there. WHY are you at 4500ISO????
The D3400 can get perfectly usable images with minimal noise up to about ISO 1600, but as was previously mentioned you're much better off keeping your ISO around 100-400 if you're in a controlled studio environment. It sounds like you're probably using a continuous lighting setup that just isn't bright enough - even with the cheapest speed lights, there's no reason you shouldn't be able to shoot at ISO 100 at f/5.6. Your best bet might be to look into some inexpensive speed lights, such as Yongnuo YN-560 or similar.
So are you saying that you were using aperture priority and letting the camera do the rest? While I agree that you do want to be able to choose the aperture, but you also want to be able to keep the shutter speed up, which leaves the ISO as the variable but using off camera lighting, you should be able to keep that under ISO1000 as long as you have enough lighting.
To be able to have this kind of control, working in manual mode typically works best.
