You have my utter sympathies, both of you! I can't tell you how often I've headed for work on only a few hours' sleep. Too much caffeine, too much wine, stress, busy-brain syndrome <<---(I made that one up years ago)...whatever...insomnia sux...![]()
Rick58 said:You should have given me a call.
I knew I should not have had that second glass of ice tea for dinner. Now I'm dressed for work again with about 3 hours of sleep. This is going to be a long day
terri said:You have my utter sympathies, both of you! I can't tell you how often I've headed for work on only a few hours' sleep. Too much caffeine, too much wine, stress, busy-brain syndrome <<---(I made that one up years ago)...whatever...insomnia sux...![]()
pgriz said:Have that as well. Went to a sleep workshop (yeah, there are those) and I learned a few things - if you want to have a good night of sleep, you need to work at it and your get body to align its rhythms with that of the night (so it's not a quick fix). Alcohol disrupts sleep patterns, so it needs to be out of your system by bed-time. Eating a hard-to-digest meal or snack means that your body will be working to digest the meal, and that too will disrupt the sleep pattern. Since sleeping is a body rhythm, having a pattern to getting to sleep is very important, and reserving the bed for sleep gives the body the signal that it needs to get into sleep mode. There is a whole series of things you can/should do to counter the normal sleep pattern distuptors, and perhaps the first step is to figure out which one (or set) is contributing to the problem. I used to have really crappy sleep, and had to re-orient my thinking on this to make getting to sleep more purposeful. Now I "usually" have a good night, except when I slip into the bad old habits.
It's a lot like fitness and eating well. If you focus on it and are consistent, you'll get results. But it's so easy to be mentally careless and get diverted by normal living.
mishele said:I've been randomly waking up between 3-4am the last couple of weeks. It's painful.
My child has prevented me from getting a good night sleep for the last 14 months. You get no sympathy from me.
They call it "passed out" for a good reason, assuming a sufficient quantity has been consumed......Alcohol disrupts sleep patterns, so it needs to be out of your system by bed-time. .......
You can probably sense my hot breath causing fog on the outside of your bedroom window and that's causing you to stir a bit. My apologies. I will try to be quieter tonight...
