Subject too dark
The boy is motion blurred.had fill flash had been used in rear curtain sync mode, the short duration of the flash of lightwould have stopped the motion.
Increasing the exposure +3.5 stops in ACR makes image noise much more visible. I also took into consideration that the boy was in dappled sunlight, so to avoid adding exposure, I took a different tack.
First I copied the 'Background' layer
On that new layer (Layer 1) I selected the boy and with the selection active I copied the layer. I then changed the blending mode on that layer (Layer 2) to 'Screen'. I then copied Layer 2 which also uses the Screen blending mode.
Lastly, I used the Sharpen tool at 100% (not the Sharpen filter) in 'Protect Detail' mode on the boy in Layer 3 to slightly mitigate the motion blur.
