sundew again
Basalt
Coventry UK
Trying to pay some attention to composition, tricky plant as the leaves on this one are long and sinuous. Slight crop.
I'm now thinking maybe I should have put the main cluster slightly closer to the centre
I like your concept, but that green stem running through the image seems so out of place.
That green stem is the leaf the droplets are attached to - there's no way to avoid it, the angle needed to give a nice crowd of tentacles means we're looking almost straight along the length, each drop is under a mm across. The whole leaf is about 20cm long and 3mm wide.
I could crop in a little closer but I'm at the limit of mag with my current set up - a macro lens plus tubes.
