AaronLLockhart
- Joined
- Jun 17, 2012
- Messages
- 889
- Reaction score
- 177
- Can others edit my Photos
- Photos NOT OK to edit
What a focal length means depends upon the sensor size. The standard 35mm film for example has a "sensor size" of 36x24mm. This is typically called full frame. You need a rectangle of diameter 43.3mm to fit a 36x24mm rectangle into it. Thus your optics need an image circle of at least 43.3mm if you want to use them on a 36x24mm sensor area. A focal length close to 43.3mm would thus be a "normal lens" for the 35mm film. Thats why, for this sensor size, a focal length of 40-60mm (sources disagree what exactly) is considered a "normal lens", while lower focal lengths are considered "wide" and longer are considered "tele" (or rather small). Another popular sensor size is APS-C, or ca 24x16mm, and diameter ~28.9mm. Here a lens of 28.9mm would have about the same view as a 43.3mm focal length on full frame. Wrong. A 18-55mm will most likely be for an APS-C sensor, with an image circle too small for full frame. Which means the 18-55mm is actually a 27-82.5mm equivalent. And a 35mm on APS-C is about 53mm on full frame, thus the 35mm is a normal focal length.
Why is it that I can almost guarantee that when I come back to read some stuff on this forum, I will see some crazy and misinformed post by you?
18mm is 18mm on both a full frame AND APS-C sensor. Sensor crop has NOTHING to do with the distance of the rear lens element to the sensor. Therefore, on both a D800 and D7000 (I'm using these two because these are the cameras I own), an 18mm focal length means that the rear lens element is 18mm away from the sensor.
What you were trying to say, is that an APS-C sensor, otherwise known as a crop sensor, produces the same FRAMING equivelant as a 27mm focal length on a full frame or 35mm camera. The focal length doesn't actually change, just what is visible in the rendered result. However, that doesn't change the fact that the rear lens element was STILL 18mm away from the sensor at the time of the shot.
