Teleconverters 1.4 vs 1.7
Tarazed
West Islip NY USA
I know this is a common question. However, I'm just looking for a little more wisdom before I make the leap. I used a Nikon 1.4 teleconverter with my 80-200 afs to shoot an outdoor soccer game with excellent results. I will likely only use the teleconverter to shoot outdoor sports as I think the lens alone has enought reach indoors. Any preference for the 1.4 vs the 1.7? Some say the 1.4 does not make enough of a difference, but, I found it very helpful. I also have a nikon 55-300 vr, but don't use it much (for sports anyway) since I got the 80-200.
Thanks
If you're happy with the 1.4, then I would stick with that. Remember every increase in the multiplication of the TC will add a corresponding increase in the effective maximum aperture of your lens.
Thanks for the reply. I have used the 1.4 but not the 1.7. Since I intend to use this combo outside almost exclusively, is the greater reach of the 1.7 worth it. Is there a real difference in image quality? Since I'll be outdoors the 1/2 stop should not be much of a factor, correct?
I have the Nikon TC-17 E II and have used it with the 70-200mm f/2.8 and 300mm f/4. I have some good results when mounted on a tripod, but hand held is another story, at least not to my satisfaction. Of course, I drinks a bit and it may be down to having the shakes. :lol:
I wouldn't use a tripod for sports. But, I must use shutter speeds that freeze the players' motion. So camera shake shouldn't be a factor for me, I hope anyway. Can a cloudy sky create issues at f4.8? Is there are noticeable difference in image quality between the 1.4 and 1.7? I'm leaning towards the 1.4. I just don't want to buy twice. Thanks for the input so far!!
Sorry not to hijack the thread, just to clarify, are teleconverters the same as extension tubes?
Nope nothing like them at all. Though it is possible that you've confused the Teleconverter with the Canon Extender - the canon extender being their market name for teleconverters (and aside from canons own sites not a single person or shop calls them anything but teleconverters anyway).
Extension tubes reduce the minimum focusing distance of a lens and remove its ability to focus to infinity. The result is a lens that can focus closer and thus get a more magnified image of the subject, whilst also losing the ability to focus on things further off. The specific distances will depend on the lens used and the amount of extension tube added.
There are two primary uses for this macro and birding
The first is on short focal length lenses (eg 50mm f1.8) to get a macro lens out of the setup where focusing really close is the idea. This also extends to some longer lenses for close up macro work such as 70-200mm, 300mm and 400mm lenses primarily focused on capturing larger insects (typically dragonflies in filght).
The second is to allow long lenses like 500mm f4, 600mm f5.6 which have very long minimum focusing distances (several meters) to focus closer; thus aiding the photographer when working in a closer hide or when able to stalk closer to smaller subjects (typically small birds).
Teleconverters on the other hand are setups which use glass (extension tubes have no glass elements inside them) to extend the focal length of the lens. They are typically aimed at being used on the top end telephoto lenses in order to get more reach. This comes at a cost however:
1.4TC - one stop of aperture lost and a minor effect on image quality (sometimes hardly noticable
1.7TC - one and a half stops of aperture lost and a more noticable image quality effect (though from what I've read its still considered quite minor by many)
2*TC - two stops of aperture lost and a very noticeable effect on image quality (this teleconverter really only works on the best of lenses for practical good quality shooting).
