There's enough content to discuss that for 64 pages?
Its all about Bernoulli's principle .. the conveyor belt is irrelevant.
OK, let's try this:
Imagine you've got a plane sitting on a runway. This runway, however, is special - it's a conveyor belt that senses the motion of the airplane's wheels. So, as soon as the airplane starts its engines and gets enough thrust to move the wheels, the conveyor belt senses this movement and rolls back the same amount that the wheels move forward. Will this plane ever leave the ground? (for purposes of this discussion, assume all frictional effects of wheels, tires, and conveyors, are null).
No it won't, because without sufficient air movement over the wings from forward motion of the airplane, no lift is generated because there is no pressure differential, which is what Bernoulli's principle is all about.
Bernoulli's principle - Wikipedia, the free encyclopedia
There is a special case of Bernoulli's principle that was investigated for a time and was know as WIG, or a wing in ground effect.
Ground effect vehicle - Wikipedia, the free encyclopedia
In the case of a airplane having engine driven propellers in front of the wings, they cannot move air over enough of the wings surface area to generate the lift required for the airplane to take flight. The angle of attack of the wing is critical for it's performance, particularly at takeoff. A wing is shaped differently by the flaps and/or slats, for takeoff and landing than for flight at normal cruising speeds.
In fact, in flight the area of the wing shielded by the propellers delivers less lift than the portion of the wing not shielded by the propellers.
Wing - Wikipedia, the free encyclopedia
