The impossible math problem...
But where do you add the people? Remember this isn't just a bunch of numbers...its based on the idea that they are real people, occupying real rooms. How do you slot the extra infinity people into the extra infinity rooms?
first come first serve, as they come in the rooms fill up. you never run out of rooms
clarinetJWD said:
it's either j or i depending on if you're a mathematition or an engineer. Now find me the Fourier Transform of this function: x(t)=e^(-|t-1|)
it's i as far as I know.
Are there more numbers between 0 and 1, or between 1 and 2?
mmmm are you meaning integers? on the integer scale, no. in float terms, yes.
unless that is some trick question, you dog :)
exactly. isn't that what the term 'float' entails? i.e. floats between 1 and 2 could be 1.1124366 or 1.809938, etc. Basically anything in beween.
i may (and most likely) have something wrong in there...i'm not really a big math buff - i got good grades but couldn't retain much for long periods of time :)
Right. In float terms, there are infinitely many numbers between 0 and 1, as well as between 1 and 2. But the original question asked if there were more numbers between one or the other. You said there are, but there aren't. It's infinity for both. ;-)
