cgipson1
- Joined
- Aug 18, 2011
- Messages
- 17,142
- Reaction score
- 4,350
- Can others edit my Photos
- Photos NOT OK to edit
so to summarize
The Yongnuo radio transmitters 622n (the better and higher priced ones vs the 603n) send the settings of the SU-800 to the remote flashes. Thus the SU-800 no longer needs to be in line of sight and in distance.
So if Nikon flashes (sb600 / sb700) with Yungnuo 622 are out of sight they would take all the setting information from the SU-800?
What control do you lose if you use OCF of the Yongnuo 560 III flash or 568ex w/622 and shoot in Manual mode and use the SU-800 to control flash output?
PocketWizard® - Using your Nikon SU-800 as a Master Controller
Check out this video. I would have to assume that the Yongnuo's work the same as the pocketwizards, but someone else will need to vouch for this.
Regards,
Jake
The Yonguos (both flashes and Wireless units) are reversed engineered to work with OEM technology... and are supposedly pretty close, but not perfect. Reverse engineering seldom duplicates every aspect of the original 100%.
