thin green line on negative scans
photocist
Oakland, CA
I just bought a epson v500 at office depot, and within 5 scans, there is this green line running from top to bottom on the left side of the image. It happens only on the color negatives. Does anyone have any idea what it could be?
edit: it appears to only happen when I use positive slide film...
Post an example?
I haven't encountered a problem like that before, but I also haven't scanned any slide film... Kinda weird that it would only show up on slides...
What software are you using for scanning? Have you tried something else to see if the problem is still there?
(Vuescan has a free trial that you can try.)
I am using the software that came with the scanner. I just found that it is not only on positive film. If I scan a strip of color negative, the line is purple.
Uploaded with ImageShack.us
Weird. Is it always in the same place?
I would suspect either the software or the scanner (not the film). Try different software and see if it's still there... I would also make sure that the software is up to date.
It is in the same place. I am pretty sure it isnt the film. I did a google search and I found one link that was semi helpful, claiming I need to clean the calibration area, but a) I have no idea where that is, and b) I just bought the damn thing, right outta the store...
It's probably dust or dirt on the "calibration area".
With the 'calibration area' - I think they're talking about the hole pattern at the ends of the film holders. Make sure those holes are clean and unobstructed. It's some kind of code the scanner reads to align itself, I think...
You have to take the glass top off to clean the calibration area.
Weird. I "cleaned" that area and I guess it works now... There wasnt even anything on that area lol...
edit: nope its still there.
Do you have a link that shows exactly where this calibration area is?
I have a V600, and I would think it's very similar... I've never had that error (though, I don't use the included software). I'd like to know what the hell they're talking about if it ever comes up though...
Which area? The holes on the film holder, or something else?
The holes were clean, and the top portion of the glass, where I think the calibration area is, is clean as well.
I might just return it tomorrow for a new one.
If all the photos are from the same roll it could be a scratch on the negatives that occurred during processing.
In the same position on every frame? Do you understand how improbable that is?
In all likelihood this is a hardware problem. Have you tried calling Epson customer service?
Hi! Sorry to revive such an old thread, but what's here is exactly what happened to me today! Only the line is on the right part instead of left!
I got my Epson V600 a few days ago...yesterday I started using it with slides, everything worked fine. Today instead the line appeared and it never went away!
It happens only with film scans, not with documents or photos. So the problem is in the upper part, the lid with the light.
I cleaned both glasses. Useless.
I opened the lid and cleaned the glass also from the inside. Useless.
The line is always there!
How did you solve, photocist? Did you get a new one?
