Derrel
Mr. Rain Cloud
- Joined
- Jul 23, 2009
- Messages
- 48,211
- Reaction score
- 18,937
- Location
- USA
- Can others edit my Photos
- Photos OK to edit
There actually is a difference between shooting crop frame and shooting full frame. I started in 2001 with a 1.5 X Nikon D1 and around 2006 I bought a Canon 5D full frame. The biggest difference is in what it does for your lenses. The D610 uses the vast back catalog of Nikon lenses designed for full frame and it uses the lens in the manner in which they were designed for. The depth of field skills for example are correct. The lenses work well in the types of situations which they were designed for. For example there is very little need for radical aspherical lens designs at the bottom end of the wide-angle tree ... On the D610 a 50mm functions as a normal and not as a moderate telephoto. On the D610 a 24 mm is quite a wide angle lens, but on the D3200 a 24 mm is like a semi-wide. The D610 older legacy auto focus in manual focusNikon lenses pretty well, and it can auto focus with a wide variety of older and fairly inexpensive F and AF and AF – D lenses, with your current D 3200 cannot order focus,and The D610 is a "two button camera". meaning it offers a front and a rear command dial, and it also allows you to use flash units that are capable of high-speed synchronization, something that the D 3200 cannot do. The D601 is a quite capable camera, and the imaging sensor is a little bit better than that found in the D3200, especially at elevated ISOnlevels. I bought myself a D610 in the summer of 2017, and I'm pretty familiar with the camera. It is a good imager, a little better than the D 3200, and the body features are a step up. as to the two flower close-ups that were posted earlier. I looked at both come and on my iPhone come seen fairly small I would say that the second photo we shot with the full frame camera
it is difficult to describe, but the full frame camera offers in nice compromise between shallow depth of field in deep depth field, per picture angle, with commonly made lenses that have been made since the 1980s. I think that the 20 mm, 24mm, 35 mm, 50 mm, 85 mm, 105 mm, 135 motor, 180 mm, 200 mm, and 300 mm prime lenses and the 24 to 70 millimeter F/2.8 and 70- 200 mm F/2.8 lenses… All of those reasonably common lenses that Nikon has made millions of work extremely well when shot on a 24 x 36 mm piece of film or digital sensor. The above lenses give us easy shooting in common locations, and at common distances. when you halve the size of the capture sensor you make and 85 mm lens nearly useless in the typical family living room, and you make a 24 mm into the equivalent of some oddball 42 mm. Olympus tried using the half frame format and it never really made it past the 1960s, and for good reason.
smaller sensors have become extremely good. larger "full frame "sensors have become extraordinarily good. With all things being equal, and they sell them are equal, a good bigger sensor will beat a good smaller sensor, Especially at elevated ISO settings.
but this is not strictly about the imaging sensor...you would be moving from Nikons least expensive, and most primitive digital single lens reflex to a mid-level camera come with several better features and better controls.
