this mornings snowfall
foster2
foster2
a park near my house was a serene and quiet place.
serene image... although it is underexposed a bit. Whites are grey! Contrast is cranked up a bit too.
Here is an edit.. I reduced contrast, so I could keep some detail in the snow and in the trees... and then increase brightness a good bit. Keep in mind that your meter will always try to turn a predominantly white scene into Grey... that is the way it works. Add a stop or two of exposure comp to compensate.
edit (still not !00% white.. as all detail would be gone) If you do not calibrate your monitor, it may be set too bright.. and makes your original look good to you.
original
yet another edit... left the high contrast, but brightened foreground to WHITE.. so you could see the difference...
^^^^ I use Safari with no problems ...you might need to update
im updated, ml, with all su's. i cant seem to upload photos to an active thread. guess thats why im listed as a noob.
