Keep practicing; there's no better way to improve! With respect to these images:
1. Nice lighting for the most part; the blacks in her hair are blocked up from the temple down, and you have some blown highlightsin the background which pull the eye away, but it appears nice and sharp. Compositionally, some minor nits (aside from the Dutch tilt, which I'll assume was delibarate; it's a personal taste thing, and not mine) are: You've cropped some of the fingers off of her right hand and the belt is blocking a couple of the fingers of her left. I think her head angle could have been a little less severe, but again, that's a deliberate choice.
2. To be honest, this one seems at best a casual snapshot rather than a portrait. She occupies very little of the frame, and the background, while somewhat defocused, is very busy and very distracting. That, combine with the severe under-exposure of her face make me think this is one that should have been left on the cutting-room floor.
In both cases supplemental light would have helped; in the first, it would have allowed you to control the ambient and avoid the blown background areas and blocked blacks in her hair, and in the second it would have allowed you to correctly expose her face and put some life in what are now, dark, lifeless eyes. They look to me (I can't check EXIF data at the moment)as though both were shot with matrix/wide-area metering. Ideally use an incident meter for this sort of work, but if you don't have one, then use your camera's spot-metering mode to do some zone calculations and allow you to work out an optimal exposure.
All that is not to say that they're bad images, BUT... there's definitely some ares for improvmenet.
Just my $00.02 worth - YMMV
~John
