Tripod night shoot of city skyline. What aperture?
Lightsped
Acworth, Georgia
So say I am standing on a hill at night trying to get a photo of a city skyline. My camera is on a tripod with the focus point on one of the buildings. Should I be using a large aperture like F2.8 or a smaller aperture like F16? Or something in the middle? Again, the camera is on a tripod so camera shake isn't a issue.
Thanks
I would use an apature equivalent of what I would use in the day time, except I would bump ISO up to an exceptable level and adjust the shutter speed to make proper exposure. So I would start at f/11 or higher, as I would like the entire city scape to be in sharp focus regardless of the time of day.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Thanks
Depends.
How far are you from the skyline you are photographing and are there foreground elements that you want in focus?
Thanks
Tripods is a must but you also need a remote cable button. The smallest shake from depressing the shutter butter can cause blurring.
As for aperture, it depends but I generally use F/8-11.
Light Guru, I'd say between a 1/4 mile and a 1/2 mile. As for foreground elements, I'd probably try some with the foreground in focus, and some shots without the foreground in focus.... I'm not sure yet.
Tailgunner, I use the built in timer on my bodies. I did recieve an aftermarket remove shutter release (wireless) button for Christmas but haven't got around to figure out how to set it up yet....
The built in timer will help but most wireless remotes I've seen is designed for quick self or group photos. Cable remotes allow you to keep the shutter open for longer periods of time. People use them to create light trails with their cityscapes.
Here is some of my cityscapes:
High fstop, low ISO and long exposure. I use the 2 second timer on my canon, before I used the intervalmeter setting on my camera so I wouldn't get shake.
f/20, iso 200 and 30 second exposure.
bridge3 by runnah555, on Flickr
F8-11, Tripod (weighted down) ISO 100, I would try to shoot hyper focal or shoot F-8 and focus 1/3 of the way through the scene. Evaluative metering. I like to under expose 2/3 to a full stop to ensure I don't get big white blobs on the hotter lights in the scene. Set your camera to use the mirror lock up function to reduce camera shake. I have a remote release, but usually just set the timer release out of laziness. Shoot at twilight vice middle of the night so you get that cool blue sky and the building faces still have their detail. (edit) Like Runnah did above. That dreamy motion blur sky is killer.
Have fun.
Eric
f/8 to f/11 will be my choice as well.
Nice!
I'd use an f-stop between f/11 and f/22. While most cameras (I didn't check the body you plan to use) become diffraction limited above f/11 (some cameras become diffraction limited around f/8) you won't notice this unless you plan to make a pretty large print.
HOWEVER... as you increase to a higher f-stop value, points of light will take on a star-like effect giving diffraction spikes which can actually be very attractive. For this reason, I sometimes deliberately go up to f/22.
As all have said... use a tripod.
Would the long exposure noise reduction help with some of the choppiness he is experiencing in the white lights?
