Trying out Black & White
LMP87
Tampa, Florida
$1975155_222129717985212_7606253224822091280_n.webp$10003506_222183427979841_3988805359519378952_n.webp$10169462_222183447979839_7237137808625623306_n.webp
Any advice would be awesome! :D
On the conversions? On the images in general? I think the conversions aren't bad; you've got a good tonal range, and and no excess shadow or highlight areas. The key to a good monochrome is to start out with a perfectly exposed image, and while the general exposure here is good, the backgrounds are definitely a little brighter than might be ideal resulting in slightly under-exposed foregrounds & faces. NEVER under-estimate the value of fill light!
IMO these are not prime candidates for B&W.
Are you making the monochromes IN CAMERA?
I suggest take all photographs in color until you happen to get a good candidate for B&W then do the conversion in post.
Until you learn to recognize a prime candidate before the shot, you will probably just have to keep experimenting until you stumble across a really good one.
What would you consider a good candidate for B&W?
I did not know there had to be a prime candidate for B&W photos.;-) If you like B&W photography, then shoot it. About 99% of everything I shoot is converted to B&W. Before digital, all my personal work was shot on B&W film. I do not even think in color anymore. So, if you like B&W, shoot away and don't worry about waiting for the right shot, that is nonsense. Good luck to you.
You have to admit, though, that some pictures look better in black and white, and others are more pleasing in color. The second one, for example, with the boats: I think that looks fine in black and white, but it also feels cluttered. There is too much in the background and the monochrome + a sharp background (rather than one blurred with a shallow depth of field) means that the eye is drawn all over the place. We tend to go for bright spots, and there are a lot of them in that shot. If it were in color, then that could help separate the elements of the photo more clearly, help us focus on the subject.
As for the third one, it's fine in black and white, but you've got something weird going on. There's a huge blown out semi-circle at the horizon and faint rings around it.
What she said. I usually look for some good contrast of dark and light in the scene to decide if I think something will work well in B&W. Lines and shapes like the boats could work well but I would have thought about moving the couple so they were in a different place in relation to the boat (so you don't look at them and see so much in the background competing for the viewer's attention).
If it's hazy or overcast I usually try to minimize the amount of sky showing, so I might have thought about where to position people to get more of the trees and not so much sky. Or with these maybe it was the time of day and/or the exposure that could have been better to give you a better photo to work with.
I really like the idea of the third one with a boat coming into the scene, and you captured her personality, but there seems to be some vignetting or something going on there.
Well, if you're just shooting random stuff including engagement shots, maybe you just accidentally find something that works as well as or better than the color version. IMO, a good B&W shot will include some or all of the following; form, line, texture, contrast, balance, symmetry, human interest, etc. A good combination of design elements that doesn't depend on color to be an integral part of the photograph should be prominent in the composition.
Now if you set out to photograph in B&W, you can watch for those design elements, and "test" each composition even before the shot. When I was "into" B&W, I would look for those elements and imagine what it would look like in B&W because I was shooting film, so I didn't just take a lot of shots willy-nilly. Shooting in B&W, or with the intention of converting all or most of your shots to B&W, you can get into the "mode" of thinking in B&W which makes it easier to "see" shots in B&W.
I hope that helps.
